My 2002 ETH with 15000 miles has been hard to start for the last 3 months or so. I was certain that the IAT sensor was bad as the grid heaters never stayed on very long. The diesel tech couldn't find anything obvious and they ended up replacing the VP-44 as a few codes had been set. The problem got better for about a week and then it got as bad as ever with some starts taking as long as 45 seconds of cranking.
Yesterday I took it back in, and it appeared that the IAT sensor was indeed bad as it was showing a reading of 140 degrees fahrenheit in the shop where the actual temperature was 60. Chrysler would not allow the tech to order a new IAT sensor and had him keep looking. He pulled all of the injectors and found the real cause of the problems, a faulty injector O-ring. This bad o-ring caused fuel drain down and soot and carbon buildup on the injectors. Somehow it also affected the readings of the IAT sensor. This part I don't quite understand. But it works perfectly now.
I'd like to give credit to Jim Harmon, the diesel service manager at Billion Dodge. Through a very frustrating diagnosis and repair process, he always kept me abreast of where they were and when they thought they could get me the truck back. When it was finished he had the truck driven to my office so I didn't have to take time off of work to get it. Not all dealers are bad!
I share this because if there is one bad injector o-ring, there is probably another out there.
