Hi all, any help you can offer here is much appreciated.
Truck began having difficulty starting about a month ago. Doesn't seem to matter if its hot/cold, overnight (doesn't get below 60 here this time of year). Replaced the lift pump, fuel lines. Started great for about four days then problem returned gradually and within a week it was hard starting every time. I've replaced the fuel pump and starter relays after researching at tdr.
If I turn the key to the run postion (but not start) and manually engage the fuel shut-off solenoid the solenoid will engage (stay up) and it starts great.
Does this mean that the solenoid is bad? I was hoping it was a voltage problem as that is easy and cheap. I also cleaned the terminals, perhaps replace the battery cables?
David
Tulsa, OK
97 2500 5sp 2wd 225K
David
Tulsa, OK
