Hard Starting / Long Cranking Time
PICS!! - My turbo is dusted, how bad is it????
Great now what??? what do you guys think?
FOXY005
Sorry this is a long one:
First a little history
I bought the truck new and it always started after 6 or 7 revolutions of the starter.
At 75,000 miles I had a long crank time before it would start, took it to the Dodge Dealer and they replaced 2 injectors and said it was good to go.
Drove it for a week and still had long crank before starting, took it back to the dealer and they replaced the remaining 4 old injectors. Which fixed the starting problem. Back to 6 to 7 revolutions to start.
At about 98,000 miles I started to get a longer cranking time before it would start it would take 12 to 15 revolutions.
I took it to the dealer and they said they checked all the pressures and all were within spec, could not duplicate the problem said if it starts within 5 seconds that is considered within specs.
Well having driven this truck since new I know what normal should be and that is not normal.
At 103,000 miles I had some crank times that were 25 to 30 revolutions before it would start, took it to a independent fuel injection service that is Chrysler and Bosch certified. They checked the fuel pump minimum of 10 pounds of pressure, checked the CP3 good, releif valve good, checked the injectors with the scan tool all good replaced the FCA as a maybe that was faulty but it made no difference still had the long crank before starting. Also no codes were set.
Went out one day last week at lunch time and had 3 cranking session of 25 to 30 revolutions to start it. That same day after work it took 4 extra long crank sessions to start the truck.
While I had it running I took it back to the independent shop and parked it in their lot and called the wife to come and pick me up, while I was waiting for the wife I tried to start the truck and it started in 12 to 15 revolutions ??
The independent shop again tested the fuel pump, CP3, injectors, releif valve and anything else they could think of and found nothing out of spec. Said it would start for them every time within 3 seconds and 5 seconds was the acceptable standard.
Of course it won't misbehave when it's in the hands of the mechanic.
I drove it for several days with cranks of 12 to 15 revolution before it would start.
Last night 2 extra long cranks before starting and again this morning 4 extra long 30 + revolutions to get it to start.
This is driving me nuts any suggestions anyone, I hope I just don't have to start throwing parts at it to find it.
I am guessing it's new injector time but they only have about 30,000 miles on them and I don't want to spend that kind of money to find out it's something else since they cant find anything out of spec. #@$%!
I use Stanadyne Lubricity Formula and Performance Formula at each fill-up I had hoped that would prolong my injector life span.
Any and all comments will be appreciated.
Thanks in advance.
I think you are right about it being injectors, with only 30,000 miles on these I didn't want to go that route if possible but oh well.
What puzzels me is that sometimes it will start on 12 or so revolutions and another time I will have to do 3 or 4 long cranks of 25 to 30 revolutions to get it to start.
Actually yesterday morning it thought it was tow truck time, but then it fired on my 4th attempt to start it.
Isn't starting fluid in the intake a no no with the grid heaters in there, without disconnecting the wires at the relays ?
Thanks for the reply, it just kind of confirmed my thoughts.
Jim
