I had the same problems like many of you: long cranks, flooring gas pedal, idle stumbling etc. Finally ordered some new marine type grade fuel hoses, new starter contacts from Larry Buck, and fuel preheater kit and molded hose (between fuel preheater and lifter pump) from the local Cummins dealer. I also replaced the overflow valve with a new unit.
In the picture you will see the ruptured hose. The cut was underneath, so it was visible only looking from the starter side.
The truck starts right away like it used to. I can't believe I made it from Sacramento to Bakersfield driving with such air/fuel leak.
Overall job took me about 6 hours. I had to use a floor jack, 10 mm wrench and 2x4 to unbolt the most stubborn starter bolt.
Thanks to all of you who posted the guidelines and how-to's articles on this annoying problem. This is one of the best boards I subscribed to.
Regards!
Denis
Regards!
Denis
