1997 Dodge Ram 2500 diesel 12v
I was having a hard time starting my truck in cooler weather. Later in the day when it warmed up a little bit, it would start fine. It was cranking fine no matter what the temperature. So I decided to check my fuel shutdown solenoid. The boot was gone and it was not moving up when you try and start it. So I used my hand to move it up where it would stay. Then had my nephew crank it over and sure enough it would start every time. I then tested the voltage to the three wire connector and had him crank it over. Voltage was good the first time, I then had him try it again. This time it will not crank over at all. I put the connector back together and still no crank. What did I do that would cause it not to crank? I also noticed the fuel shutdown solenoid will no longer stay up when I do it by hand.
