O. K. Guys, I need your help and guidance. I made a post last week about my truck starting hard after sitting overnight. Most of you thought it was the return fuel line,which I still think it is - this is where I need your help - I just crawled out from under my truck and I have diesel fuel dripping from the drivers side frame rail. I've found two lines with plastic protective loaming material covering two metal wire braided flexible lines. I can't tell if the fittings on the lines are leaking or not. Are the flexible lines the original ones or a D/C fix?? The starter has no fuel on it and the rubber lines farther up don't appear to have any raw fuel on them either. I haven't really got a good look at the lines farther up near the fuel filter and I assume those are the ones that usually have to be replaced. The braided lines appear to have a plastic connecter fitting similar to the infamous transmission lines. Should I replace these lines or leave well enough alone?? I've removed the plastic protective loaming to see if I can see where the leak is at.
Any thoughts or suggestions would be appreciated!!!!
