hard starting
Low Sulfur Fuel
Uh oh gas in the tank.
Occasionally my 05' will crank and crank, with no start. If you turn key off then try starting again it will typically fire right up. When it fires it will put a large cloud of blue smoke. This has happened since day 1. The truck has just shy of 16k miles now. All i can think is that maybe an injector is losing prime? (after reading other injector failures on numerous threads) Any ideas? If injectors are the culprit i have no problem upgrading them with some new ones. Can anyone tell me about the Kax injectors and if they are worth a damn. Timberline Dodge in Portland Oregon sells them for 1200. 00 installed and they are fully warrantied. I believe they are reworked factory injectors but not positive?
My KAX injectors had been doing great, now I'm not sure whats wrong. Initial report say it might not be the injectors, but the relief valve. The KAX did dyno as advertised, 80+ hp, little to no smoke. I met the guy that builds them, knows his stuff, does a LOT of viper stuff. He is in Vancouver right off I5.
JRG
made a trip to timberline dodge yesterday. computer was updated and kax injectors installed. WOW... . no more smoke on start up and seems to fire up every time as of now. not sure of exact power increase but seems to give quite a bit more zip. enough to go to get tickets and go to jail. LOL... . 18. 1 mpg nothing under 65mph alot of 80mph plus spirts.
