From the archives:
I had a similiar problem and solved it.
My motor is an '03 HO ISB-305 installed in a Hummer H1. The truck ran fine for a year or so, then I got some bad fuel in January. I went through 3 fuel filters until it ran fine. It got progressively harder to start. Once started, it runs great. The fuel could have caused the problem, I can't be sure.
Since it ran fine, I suspected the CP3 was OK and the problem was a leaky injector. When an injector leaks badly, the rail cannot pressurize itself enough to start. Once it starts, the system (as you describe) runs fine and there is 6000psi at the rail even with a leaky injector.
I read up all I could on this and decided to buy a Quadzilla rail pressure gauge to confirm my findings.
Prior to this I checked the FCA and overpressure valve, both were fine.
Sure enough, the rail pressure during crank was 300-600 psi. You need about 4000 or higher for it to start.
A friend runs one of the 18 Cummins service centers across the country.
He's a offroader (a Jeeper) but was tickled to see a common rail in a Hummer.
He offered to have a tech look at it (as a favor).
I told the tech everything I found (sent him a long email) and we decided to cut to the chase and cap off the rail one injector at a time.
We started with capping off #1, and sure enough, the truck fired right up (I did it a dozen times). We moved the cap to #2 and the truck didn't want to start. I moved the cap back to #1 and it started right up. While you can do a leak down test, I didn't feel it was necessary. This whole test took about an hour.
I ordered an injector, it took about an hour to replace. The truck started right up.
The Cummins part # for the rail cap is #3164325 and it's about $30. I'm going to order the leak down bolt (that goes on the back of the block) so I can do further testing down the road.
A new injector was just over $300. That included a injector nozzle which I'll keep as a spare.
Now if you have several leaky injectors, this will be a bit harder to test on your own and you'll need a few rail caps and want to measure the amt of fuel coming off the back of the head.
I also stopped by another high end diesel shop and talked to their service manager. For me anyway, I found that if you've read up on how the system works, and don't appear lazy, the service managers and techs will be happy to fill in any blanks.
You can always pull all 6 injectors (not hard - 2-3 hours) and send them out for testing. Or buy a rail cap like I did and try to figure it out on your own.
Frankly, if you bought 5 rail caps and capped off all injectors but one at a time and hooked up a plastic tube to a measuring jar, you'd find out which one(s) leaked considerably. The Quadzilla rail pressure gauge (about $180) will confirm if your hard start is from a leaky injector(s)
So check the FCA and pressure relief valve, and order some caps. It worked for me. By the way, I'm not a mechanic, I write software - I just enjoy building stuff and want to know how things work since if I break down on a trail, I need to be able to fix it.
When you get your injectors, inspect each injector body for tiny cracks.
I'm going to order to special bolt that you use to replace the banjo bolt on the back of the block for measuring leak down into a glass jar. I'll post the part # when I get it.
Good Luck and post what you find. .
__________________
