I'm having trouble with my 95 12v p pump. After starting fluid is used it start and runs great above 1000rpm anything under 900 it is sluggish till 1100 then snappy 18° of advance on the pump. High pressure eletric pump feeding lift pump, heater eliminated checked all return lines and fittings can't seem to find air leak. Solenoid is working properly. Ideas? I have a aftermarket fuel pressure regulator/snubber. New filter also symptoms haven't changed. Rod
