hard starting
So you want to buy a Box for your truck....
Killer Pin Question-
IS THERE ANYONE OUT THERE THAT HAS EXPERIENCED HARD STARTING AFTER TRUCK HAS BEEN SITTING FOR 2 OR 3 HRS.
I HAD MY HEAD GASKET REPLACED UNDER WARRANTY AND EVER SINCE I GOT IT BACK I'VE BEEN EXPERIENCING OVER LONG ENGINE CRANKING BEFORE IT STARTS. THE DEALERSHIP REPLACED THE TRANSFER PUMP, ALL GASKETS ON THE BANJO FUEL FITTINGS, FUEL FILTER AS WELL AS THE CHECK VALVE LOCATED ON THE INJECTOR PUMP. tHE TRUCK STARTED NORMALLY FOR 3 OR 4 DAYS AFTER THE CHECK VALVE WAS REPLACED. tHEY HAVE NOW GIVEN UP AND ARE SAYING THE PROBLEM IS NOT RELATED TO ANYTHING THEY DONE.
IF ANYONE HAS HAD A SIMILAR PROBLEM OR HAS ANY SUGGESTIONS PLEASE CONTACT ME.
THANKS,
-- email address removed -- :confused:
