Trying to figure this out. A couple weeks ago the 3500 started to require just a little more cranking to get her going (warm & cold). Not bad, only about 1/2 rev. more than the normal bump of the starter. It got worse, until it got to the point of not starting at all. Fuel pressure is right where it should be, 14 - 16@idle & around 10 at WOT. Runs great when running, except rough at 2k w/ no load - but this is not new. Checked codes - none. Fresh filter.
Next - change fuel lines from tank to lift pump incase of air leak. I get a nice syphon at the lift pump, so I know that all well in that department. After the fuel line change, she is back to where the troubles began, requiring just a little more cranking than necessary. I'm not sure where to go from here.
In the back of my head I have been thinking that my VP is taking a dump, (this is still the origional VP w/ 135k) and I have been expecting it to go. I have no problem replacing the VP if it is bad, but I don't want to if it's not the problem. Is there any way to figure out if it is indeed going south? I don't realy want to just wait until it gets worse. Once winter gets here, this truck needs to start everytime, no excuses. If it needs a VP, I would like to get it on before Nov.
Thanks
Thanks
