I just replace my steering box and steering shaft with borgeson products. The damper is also new. I bleed the power steering line by moving the steering wheel side to side with wheels off the ground and the engine running. The steering is very easy to turn with the wheels off the ground. When I put the tires on the ground and try steering when applying the brakes at low speeds I lose power steering. (Still haven't had the alinement done) My truck is a 2000 quad cab 4x4 2500 automatic 162000 miles. Any help???
