Hardline HELP??
I just saved $40.95 on an air filter!
Auxiliary Lighting for my Beast
Well I orderd the Practical solutions and got the boot modual on and couldnt figure out the elbow deal so I called Gordon and after checking under the Turbo I guess I have a hardline so I cant use the practical soutions. Unless anybody can help, i have to send the PS back to Gordon. I have herd it really goes good with the 275's but im stuck between a rock and a "hardline" #ad
Can anyone help me?
Sky
2001 QuadCab,SWB,Auto, 4X4,4" Flowmaster Exhaust, Bosch 275 Injectors... ... ...
I'm not sure what kind of boost you are lookin for but, when I had the HY 35 turbo on mine I figured out a way to plug it off. What you need to do is, loosen the two bolts on the wastegate accuator. Then pull the hardline out of the compressor part of the turbo. Once you've done that you can turn it so that you can see inside the hardline. Next, get you a set screw that will fit inside the hardline (not sure what size I used), put some loctite around the set screw when you put it in the hardline (a little pain in the butt to do, take your time). I would reccomend that you let it set for a few so that the loctite will setup and none of it will blow out b/c of it still being wet. After you do that just put the hardline back into the compressor and tighten the bolts up on the accuator. You should be set now. You should be able to use the PS now, b/c if you don't the truck will deffinately defuel. Feel free to ask if you have any other questions. Thanks, good luck to you!
  • 2001 Cummins, Black, QC, SWB, Agate Leather, Every Option Available
  • 3:55's, Auto, 4x4, 2. 5" Skyjacker, 33x12. 50 BFG Mudders on 16. 5x9. 75 Weld Super Singles
  • JVD Torque Enhancer, Big 425 hp Injectors, Boost Module, HX35 w/12cm housing non-wastegated, High Stall Pro Torque Convertor, Performance Valve Body, Silencer Ring removed
  • No Muffler, No Resonator, Isspro Boost/Pyrometer Guages mounted on A-pillar
  • Dee Zee Diamond Plate Toolbox, Bed Rails, Tailgate Protector, Chrome Rocker Panels, 4" Chrome Tip
  • Cobra 29 Sound Tracker Night Watch CB
I used a 22 rifle shell (that had been fired) and worked it over with some emery paper and it slid right into the hardline. Effectively blocks the waste gate. And besides that it is cheap. .
01 2500 SLT+ QC LWB 4x4 Auto 3. 54 rear end Forrest Green Sport with all options avail DC Nerf Bars, DC Grill Gard, DC mud flaps, Line-X bed liner, Leer 160XL Topper, Power Edge, EZ Edge, SPA Boost/EGT Gauge on pillar mount, DDT's torque converter - valve body combo and 275 injectors.
4" Exhaust on deck. Air box mods and a new turbo in planning stages.
See My Truck
Dads truck: 98. 5 3500 SLT QC LWB 4x4
Brother Truck: 92 W250 SLT CC LWB 4x4 (Dads old truck)
See 5 Diesels and a Gasser
Winter fun: 2000 Skidoo Summit 700
JR2 -
Thats all ya did was slide a shell into it? In between the black tube and the turbo correct? Maybe I'll try that, looks like its gonna be a couple weeks before I get the HX40 on. Anything else you did? What are your typical boost numbers? Thanks.
Kat,
You STILL don't have the HX40 on? Waiting for Jet Hot or something?
Chris Timochko
1997 5sp 4X4, HX40, BD 4" Brake, Marine Compression, Custom Tuned Injection Pump, 370B Injection Nozzles, Delivery Valves, Governor & AFC Spring Kit, Psychotty Air, Water Injection, NOS Diesel Kit, 6" Chrome Exhaust System, No Smoke Valet Switch, McLeod Dual Disc Clutch, Mag-Hytec Rear Cover, Cummins Chrome Kit, Optima Red Tops, Hadley Bully Horns, Hurst Line Loc, Goodyear Wrangler AT/S 305/70/16s. Test mule for Auto Wurks Diesel race program
Originally posted by DieselB59:
Kat,
<font color=blue>Bingo! Well actually I am waiting until I get some more BOMB'ing money saved up. I just had to renew my insurance on the truck for a year, so that was a major setback. But yes waiting to get it Jet-Hot coated still. One of these days... ... ..... makes a nice conversation piece #ad
Got the HX40 and the ATS manifold sitting right here next to the PC. Starting to get tempted to bypass Jet-Hot and just slap it on..... but trying to have a lil patience! #ad
<font size=-2>
[This message has been edited by KatDiesel (edited 11-21-2000). ]
Sky... Use the 22 shell trick. . As JR2 said it slips in after some emery cloth work or what I did, took some tin snips and cut a slit in it and pushed it in. This works great and completely stealth. You won't get any increase in boost over factory 20psi until you do this. The PS boost module only fools your ECM not to over boost. I'm getting between 29-30psi of boost.
