Hardline Wastegate Mod - EZ
Whats Wrong No Smoke
Auto and PE EZ?
to clear the codes from the ECM you need a special scan tool that is not available to everyone.
Dealers and Cummins can clear codes
Even clearing the codes with a standard DRB scantool does not clear the fuel faults in the Cummins ECM. I have seen this many times. The non-wireclip boxes leave no physical trace, but electronically, they leave their signature. However, to see these fuel faults, it has to be done with the Cummins software and datalink.
Question For Evan and Bob !
Are these codes set forever? Will they clear if both batteries are disconnected for 30 minutes? If that is the case, I should just cancel my extended warrantee and get part of the money back. :confused: :rolleyes: :confused:
