Has anyone been Smoke tested yet?
Speedometer Blues
NV4500 In my 93
In New York City, we just started to test opacity (smoke density) in Diesel trucks over 8000 Lb GVW, and that means me (in Nov. ) and anyone else in the NYC Metro area. Being a state inspector, I have been doing tests on Heavy trucks and the Pass rate is good. I want to do the pump and Injectors on my rig, but don't want to start huffing. I did test a 12,000 Hour tired 6-71 powered smoker (blue and black) and it passed so I would think a ram would have to be real bad to not pass. Just something to think about.
'92 W250,3. 54,auto,reg cab, raven hi top cap, tach,boost,transtemp,pyro. 16cm housing.
In the Greater Vancouver, B. C. , Canada we have had exhaust emissions testing for a number of years now. My 92 Ram has always passed. #ad
92-LE,Cummins,Tach,4x4,5spd,3. 54,Borgeson steering shaft,
Wayne M. , I am also a State DMV inspector, I work for the State. We are waiting for our machine to test diesels. I am about to "upgrade" my 93 D350 with PW injectors and a 14 cm turbohousing. I am concerned with the test for smoke opacity. Perhaps I will have to turn my injector pump down after injectors+turbo housing. I am still at stock settings. Do you think we will pass the test?Rick.
93D350,K+N,B+M deep pan,trans-go shift kit Banks pyro+boost+oil temp gauges,dual batteries.
Rick, The way my truck runs (stock) I don't see a problem. Before the test you actually do clean- out snaps. I'm sure the limits for opacity are curved depending on an age factor but the number i've seen has been 40% and there have been no failures yet. 40 has to look REAL bad! Are you out of the metro aera? I thought you didn't have to test up there. What agency are you with? I am a City employee.
Wayne M. , I work for NYS Parks, and I live/work on LI south shore. Thanks for the info on emissions test. Were you at TDR rally in Southampton in July? Later Rick.
Wayne, I just had the test. Passed with an average 14. 3% with very slight exhaust smoke showing at 3000 RPM. >40% = fail. Totally stock 12v motor. I think clouds of black soot out of the pipe would >40% and fail, otherwise what's the point of the test ?
Ron
98 3500 QC 4X4 Int Blue, 6BTA5. 9, Auto 3. 54 LSD, PIAA Pro90's, RS9000's, Tonneau, Running Boards, 5K Air Bags, Hadley Air Horns, EGT/Boost/transmission Temp Gauges, Cobra / K40, Valley class V, Bugflector II, Bedliner, Tow Hooks, Cup Smoothie, Meg's turn-down tip, SS Fender Flares... .....
99 Lance 1110 Slide-On Truck Camper
[This message has been edited by FF1063 (edited 09-10-2000). ]
Hi Rick, no, I wasn't at the Buzz chew show, how was it? that weekend has always been a busy one for me. I was really looking forward to going to the Diesel nats @ Englishtown this weekend just to hang out but now I have to work, guess we'll see.
FYI on the Smoke testing, We just had in an older mid '80's Mack and it Failed. The threshold was 55% (I guess the limit does go up with age, but won't apply to us) and failed @ 77%, this thing was HUFFING! we're in the process of doing injectors, timing, and making sure the AFC is ok then we will try again. 77% looks real bad at the stack.
Wayne M, The TDR rally at Buzz Chew was real good. One guy brought a 1927 Cummins stationary engine sounded/looked good. Another guy showed his new 2000? 4 door + extended cab all black custom truck!Thanks for the inspection test info, I have several 6 cyl. Macks that will likely fail the test.
Geez, everyone gang up on the Macks. #ad
They were built before pollution control, and good air/fuel control LOL. #ad
Jason's Lil' Mack - 89 D250LE 2WD 5 Spd 3. 54 Reg Cab. K&N,"tweaked pump", BD Injectors, Banks Pyro/Boost, 3. 5" Exst tail section straight. 23 Psi boost.
E&M Custom seats. Bosch H4, PIAA 80W/80W HdLites. 100W Drv,55W Fogs.
232,500 miles (372,000 Kms) 7700 Hrs.
The Original Turbo Diesel
WHOA!!!!!!!!!! I never did slam any Mack Trucks! I was only telling my experience with the smoke meter. However they do like to puff and that don't make 'em bad in my book. If anything, it might make me a better mechanic after I make it pass! They have to be the most reliable pieces the City owns! Of course that goes for the pre electronic trucks!
