Has anyone experienced this?
Another newby
Smoke while accelerating with DD1 and PS boost module
Just recently the throttle pettle has begun to pulse at certain speeds usually around a steady 50mph. The engine does not surge nor do the rpms fluctuate, almost like when you set the cruise and you feel the pettle move away from your foot. It feels like it moves away and then returns.
98. 5 2500 QC,SB W/ camper shell, whitw w/driftwood lower, 2wd,3. 54, loaded w/o leather,chrome Westin step bars, BD tc/vb and pressureloc,w/trans temp,4" BD exhaust from turbo back, firestone airbags, heavy duty pullrite hitch, Bug sheilds, 4x4 type mud flaps front and back, Amsoil bypass & air filter. Dual pyro-boost gauge,pillar mount, PS boost mod and elbow,
VA cpc and fuel pressure gauge, Pac-Brake.
i see your sig says you have a pressurelock , i would look at that FIRSTY . disconnect the piston and tie it out of the way , i bet that fixes it . call bill k. he will tell you the samething , i think thats his baby .
It is the Pressureloc, been there done that!
TAZ... 2001 2500 SLT+ 4X4 Auto ETC Cummins, LSD 3. 54,Quad Cab, Long Bed, Agate Leather, White/Driftwood Exterior, Sliding rear window, Camper Special Group, Towing Group, Cab clearance lights,SPA-Technique Digital Dual Gauges (Pyro/Boost, Trans pressure/temp) Aux. Backup lamps. BNM 5th Wheel Hitch, Additional Body Molding on Bed. Line-X bed-liner. DTT's TC & VB, Pac Brake, Power Edge, Edge EZ, Grover Air Horns
2000 32' Aljo Triple Slide 5th Wheel.
http://www.ramtaz.com
Add on's to come: any other Ram Runner required modifications...
