Momentary "Ignition" Cut-Out!
Fishn'Fool
Member
posted 04-09-2001 07:16 PM
I don't like the feeling I have about his one... . Twice now (a few days apart) I have experienced a momentary "cut-out" of the engine when accelerating away from a light.
It last for a fraction of a second but it has scared the crap out of me both times. Engine is running great in every other respect.
From some past posts I'm sure it is something with the TPS, ECU, CIA, FBI, or some other electronic component on this beast.
Any thoughts?
'99 4x4, 5 speed,white, loaded with factory goodies QC Sport. Still in Flight Training, gear-head Diesel truck loving newbie!
Ramboy
Member
posted 04-09-2001 08:03 PM
I have had the same thing happen as well as a lot of other people on here. Mine didn't do it till I started bombing so I figure it could be something electronic. But I am just guessing like everyone else.
Phil
'99 D3500, auto. ,2WD,3. 55 LSD, all options, Banks Power Pack w/K&N filter,DTT TC & VB, Mag-Hytec pan, '99 40ft. Alfa Gold Triple-slide 5'er
Todd T
Member
posted 04-09-2001 08:08 PM
i would start with the Camshaft Position Sensor, the reason why is if it flacked out the ecm wouldnt know what to do, and they have been failing in a limited number of cases. just a place to start. you might put a scan tool on it and run it while monitoring the sensor.
since this is in the 24v section and i didnt look at your signature, i am assumming it is a 24v'er if not then do the same for the Crankshaft sensor.
Todd,
2001 Q-cab SB 4x4 5spd 3. 55's, A pillar Boost/EGT,Jardines 4" turboback kit,custom built aluminum airbox W/K&N-RE0860 through the cowl, and more to come...
[This message has been edited by Todd T (edited 04-09-2001). ]
ToolManTimTaylor1
Member
posted 04-09-2001 09:30 PM
Ten Bucks the code that would show will be p0500 = lost communications with Vehicle Speed Sensor. Happened to me one a month and the last two times I checked the code and found this p-code. Allmost like leaving a light and 300 feet later (or howmany) it's like someone reaced over and switched the key off and on realy quick.
cycle the key from off to on 3 times ending in the on position and see what comes up in the mileage window.
Truck Bio:
Y2K+1 3500 4X4 Quad Cab L. S. D 4:10:1 Powerpacked (4 inch exhaust,High ram intake,wastgate mod to 38 psi,otto +guages,K&N) , Jakit's Front End Leveling Kit with 255/85R16 BFG M/T's Custom Rhino Liner (see tool man's truck feature)DeeZee Goodies, Mopar Performance accessories-Sill plates-hitch cover-cargo aux lamp'n'Power, Hadley air systems 150 psi comp and air storage. Rubber side down & shiny side up can get a smile at the end of each day(hopefully)See The Rig Here
Fishn'Fool
Member
posted 04-09-2001 10:51 PM
Tool Man Tim,
You described the problem to a "T". It was exactly like somebody ran over and switched it off then back on in a split second about 100 ft. from the light!
I can't make my machine give up any codes throug the 3 times off and on trick. Does anybody know what the procedure is to get a 1999 year truck to display it's fault codes in the odometer window?
Thanks everybody, this site is awesome for the mechanically caring and curious of their beast!
RobbyRam
Member
posted 04-10-2001 01:12 AM
Mine did the same thing until I got my ECM reflashed at the dealer. There is a TSB for it but I'm too lazy to go out tonight and look under the hood where the TSB # is recorded, sorry.
Y2K Awesome Black LB 3500 QC SLT, 24Valve ETC ISB, 4x4, 4:10 LSD, DTT Custom prepared Auto transmission VB, Power Edge 'EZ', DD2's, K&N, Polished Stull Billet Grill/Fog inserts, Chrome Smitty-Built Step Rails, Mopar Chrome-Tipped Mud Flaps, A-Pillar mounted West-Tach Turbo/Pyro/Trans Temp gauges, Rancho 9000's, Diamond Plated Tool Box, + a bunch of other stuff. Fact:The First Fords' had 'DODGE' Engines! The new PSD's need them!
mikel
Member
posted 04-10-2001 10:22 AM
Mine has done this since about a month after I got it. It's been doing it for nearly 30K. It has never shown any codes, and I do not have anything positive to say about any of the times that the dealers have reflashed the computer in my truck. My advice is to leave it alone until it breaks, then the real problem will be easy to find.
Mike
'99 QC 2500 SLT Driftwood 2wd SB 24v Auto 3. 55 LSD
ISSPRO boost and pyrometer, Autometer 3 gauge replacement pillar, Walker 24168, DTT VB
'00 Durango SLT 360, 3. 55, Patriot Blue
big_cummins_ram@yahoo.com
Howdy Agg's!
[This message has been edited by ToolManTimTaylor1 (edited 04-11-2001). ]
