Has anyone had to replace air intake temp. sensor?
ignition switch problems
Fuel Solenoid Boot
I have been having problems starting my truck when it is cold outside. Around 25 degrees. I took the starter off and nothing appears to be wrong with it. Could it be the air intake sensor is gone bad. If so has anyone ever had to replace one. About what was the cost and how big a job was it to do. Thank you
Did you check to see if there is 12V at the intake heater terminals when it's cold?
Joe George
Eureka, CA
'95 2500 CC auto 4X4,3. 54,Combo EGT/boost guage,custom switch panel,PacBrake,TST #5,BD valve body,Automatic motorhome steps on both sides,Foldacover hard bed cover,Cummins chrome kit,Black steel grill guard,Front hitch receiver
[This message has been edited by Joe G. (edited 12-06-2000). ]
just had the same problem on my 94. i assume you starter is turning when you hit the switch but have to keep cranking to get it started? i checked the pcm fault codes with on-off switch method and it showed that mine was bad,,,on cold days the intake heater would only cycle for a second then back off,not enough to get it started,took out the air temp sensor and cleaned the connections the best i could & put it back in and now it's fine ,now it tells the intake heaters to stay on longer due to the cold temp. i bought a new air temp sens. anyway just incase mine acts up again. could only get one at a dealer and it was $23. just as easy as changing a spark plug
94 2500 4x4 SLT,auto,180,000 miles,3:54,brilliant blue/silver,tst 250/635,pump turned up 20%,k&n,gauges,cat gutted,
2001 3500 4x4 q-cab slt,auto,4500 miles,3:55lsd,brite silver,stock (for now)both have 12k hitches&15k's in the beds,30ft fourwinds 5er,(MY RAMS) http://albums.photopoint.com/j/AlbumIndex?u=1360183&a=10142301
