Has anyone here bought the full splined shaft or transmission from Stand.trans???
Propylene Glycol Antifreeze and Engine Coolant
12 valve 6 speeds??
My last post on this transmission thing. Gotta "sh*t or get off the pot" as the old timmers say.
Has anybody here purchased a trans from Standerd trans in Texas with the full splined 5th gear shaft or the up grade splined shaft>??
If so, how many miles and how has it held up?
I've gotta make a move on this transmission problem shortly... I appreciate your input and opinions greatly.
Thanks again, Ed
1997 3500 Dually CC, Emerald Green 5 speed, 4:10 , Reese 15K 5th hitch, K&N Air Filter, Jacob E-brake, gutted cat, running boards. Maybe more,if I can keep it out of DC'$ hands. .
Bug O:
Thanks for putting the question out there. Like you, I'm going to have to make a decision on this fairly soon. The only thing holding me back from buying the Standard Transmission "fix" is lack of feedback from other members. If you've installed it, please let us hear from you.
'94 SLT 2WD, 5 Spd. , TST #6(250/635), 215 HP Injectors, Calibrated Pump, 14. 5 cm2 Turbo, ATS Exhaust Manifold, 3. 54, all Synthetics, By-Pass Filtration, EGT & Boost Gauges, Psychotty Air System, 4 " exhaust, BD Exhaust Brake, Horton Fan, Prime-Loc, Cummins Chrome Kit, Homeless Cat, Air Lifts, Rancho RS9000's, PIAA's, 255x85Rx16's and copious amounts of 12v Pride.
The best thing to do is to call Mike Patton at Standard Transmission and Gear and talk to him. 817. 625. 7109. I spoke with Joe Donneley at the Texas Rally, he had stopped and visited with Mike Patton on the way to the rally and seemed to have good things to say.
Mike is a good honest guy, smart, and seems to have found the handle for your 5th gear nut problem; he can explain it to you in simple terms. I know this comes from an auto transmission guy, but I have met him and he makes sense.
1998 Driftwood Extended Cab,short box,12 valve,4X4,automatic,3. 55 rear end,fuel plate,Rickson 19. 5's,Abbott EPRA, Rancho Shocks,Heim trackbar,Mag-Hytec transmission pan and differential cover,Ranchhand Bull Nose front bumper, headache rack with side rails, in bed tool chest, side steps and rear bumper.
[This message has been edited by DOWG (edited 09-27-2000). ]
I bought the mainshaft, bearing and nut "kit" from Standard Transmission. I know Joe did, also.
I am keeping mine on hold until the nut falls off again, or find a mechanic I trust to do the job. I think Joe is in the same position at this time. We have a friend who had it done, but not enough miles to draw any conclusions. My last (and olnly) fix was over 25,000 miles ago and I stopped babying it. Who knows? At least I have the parts for the when, not if... ... ... ...
'99 Quad long bed, 4x4, 5 speed, 3. 55 limslip, DD stage IIs/boost module and elbow, US Gear D-brake, Mag-Hytec, 4" exhaust, gauges, stock filter, air bags and a bunch of other stuff. Pull a 30' Wildwood
fifth wheel.
Update:
Well, I decided today to go ahead and buy one of the rebuilt trans from Standerd in Fort Worth, Tx.
I figured with a 10,000 mile warranty and the full splined shaft, and the nut being staked on mutiple times by them, would offer me the best chance of uninterupted travels. . I hope, anyway.
I hate being a "trail blazer", but oh well.
While i was at a trans shop in my area, I found another Ram 1 ton 5 speed with a bum 5th gear. . This poor guy had already "welded" his spun nut on the shaft, but it broke the shaft...
That made the decision for me. .
I'm suprised no one on the board has actually bought/used their parts. . I hope to be able to give good news as time goes.
thanks for the input and help. Ed
Errrr, did you say 10,000 mile warrantey ? Thats 1 month of runs for me..... Bummer Mike
92 Std cab. LE. 215 P-pump reman cummins motor. 5-speed, 3. 54, 105 gal Aux tank in bed. Borgeson shaft, Banks Power pack. 12cm Hot end housing w/wastegate. 4" Exh, Pyro & boost guage, oil temp guage. E-brake. Galaxy DX99V, Used as a Hotshot/express Reg. at 36,000 lbs in 48 states. http://hometown. aol.com/hotshothauler/myhomepage/business.html 2000, 3500 being setup for Hotshot work as we speak. 250 miles todate
Intersting post!
When you next call them ,ask who is the guy's name from ind. that lead them to the idea (fix that works) and did or did'nt they , in 97/98 offer a one year -unlimited miles warranty on ther reman transmission and later change'd there policy because the OE could'nt and would'nt give that warranty .
Don't get me wrong. There good people,but just covering there A--'s $$. Also ask them
if i told them about the piolt bushing from South Bend clutch. Told a guy in the Jeep building in Detroit and from another source My latest info is Valeo is(clutch mfg) using it as OE starting in 2002 model year. Who'd have thunk????????????Most likely see a TSB late in the year (2001) about the new replacement. Just my guestamation!!!!!!
And some one said -hole machined off center!!! Arn't we imbearassed!! A rip off some dealers are telling owners to a tune of $600. A nother note if you have a (extra) flywheel(above stated ) e-mail first- and i will buy it.
One of these days i will send in a picture of my truck with miles But Why hurry??????????
Won't get a decal for anything with over 3k they must not belive in a Ram!!!!!!!!!!!!!!!!!!!!!!!!!
How hard is it to change a 2-3
3-4
4-5
5-6
6-7
and so on DON'T forget the K. TDR
96-3500 SLT EXT. CAB AM/FM/CD-RINO LINER. D-CELERATOR EXH. BRK-RED LINE VAC. OVER HYD BRK CONTROL- AIR BAGS W/HVY DUTY AIR COMP. PUTCO S/STEEL DEEPBOARDS FRONT TO REAR. REESE 20K 5TH WHEEL & GOOSE -REESE 20K HITCH BELOW W/17K RECEVER. CLEAR COATED & SOUND DEADINGING &UNDER COATED 5 SPD/W 4:10 MCHLN'S 235/16'S UNIDEN PC76/WEATHER-WILSON 1000 MAG MOUNT ANT. 4 WHL ANTI LOC BRK SYS.
