OK, here is what I am getting at...
On my Throttle Position Sensor (TPS) I have noticed that the 0-100% range is 'dead on' BUT the two idle switches (ON idle and OFF idle) have a heck of a lot of hysteresis. In layman's terms, it takes quite a bit of throttle to get the switches to pick up during 'OFF idle' and is real noticeable when going downhill with very little throttle.
The reason why I want to adjust the switches is because they command the Torque Converter to lock or unlock. I would like it to stay locked during these downhill moments when you are giving it very little throttle.
Has ANYONE been inside??? Before I take the plunge and take out the hysteresis on my switches (readjust) I thought I would check if there are any others 1: with the same problem and 2: people anal enough to have it bother them and dig into the TPS.
I will dive into the thing because it bugs me, but checking info before 'tearing in'.
ANY input would be helpful, and as I understand it, DC doesn't even adjust the things... just replaces them.
Thanks.
Thanks.
