I dit it
I installed my hitch on Monday. It took about 4 hours, only because I kept getting nervous about drilling holes. This same hitch was installed in my 2000 Dodge 2500, and I had the guy from whom I purchased the hitch do the install. He did a good job. But, when I purchased my '01 a year later, I took the hitch and installed it myself. The easy part was that it was essentially going in an identical truck. The only difference in my new truck was the HO 6sp vs the SO/Auto in my Y2k. It was pretty easy, but I was still nervous.
This time, I couldn't just copy what I did in the other truck. So, I had to take my time and make sure I did it right. I measured about 16 times, and cut once for each hole.
If I were to do it again, I'd say I could do it in about an hour and a half. Less time if I had help. Yes, I did this completely solo.
The one thing I really didlike is the fact that the hitch is centered right above the axle. I had the Hitch installed 2" forward of the rear axle in the other truck. This put a little weight on the front wheels, and the truck was really stable. I've noticed in the new one that the truck tends to buck a little. I'm currently trying to figure a way to fab some brackets to move the rails forward an inch or two. After getting the brackets on, I think Reese could have designed brackets to do just this. But, now that I've drilled holes in the bed and frame, I don't think I'll be moving them jsut to drill a bunck of more wholes. Aye corrumba!
I had my instructions from the hitch rails from the last time. The first three pages cover the general stuff, and then there are a page each covering all the specifics of the "Big Three" for years '73 to current. Of course these were 4 years old. But, the new bracket kit came with a sheet covering the applications for which the backets are used (3rd Gen 2500/3500 w/overloads). You can also call Reese and ask for instructions. They'll email 'em to ya.
FYI, Reese and Draw Tite, from what I've seen, are exactly the same thing. They just use different stickers and part numbers.
Oh, and it would have been nice to know the trick with the hole saw and plywood
Not a difficult install. Instructions are good. It's just scary drilling holes in your new truck!
Now, I'm also trying to figure out where to put the pigtail. In my 2nd Gen, the plug was on the hitch. I put a plug in the side of the bed behind the wheel well, and ran the pigtail from it to the plug on the hitch. Now, with the factory plug up by the license plate, the pigtail comes out under the bumper. What are you fellas doing?
SOLER
