Engine/Transmission (1998.5 - 2002) has anyone used #4 fuel oil in their cummins?
2nd Gen Non-Engine/Transmission Radio, Left side Dead
Engine/Transmission (1998.5 - 2002) Gould seal-kit vacume-pump
I woudnt even consider it unless it was cut with kerosene at least 50%. Even then, only in the hot weather.
Especially with a 24V engine & it's delicate pump.
JM. 02
i run used engine oil in mine. but you need to keep the pick up screen clean. i took mine out and put a draw straw in and then put a pre filter outside the tank.
I planned on cutting it with kero and running it through a 3 micron filter before in goes in the truck, I would think it has better lube than todays diesel
