Go easy, this is my first post!
I've been reading all about the problems with the hesitation and surging, and it seems that I, too have a similar problem. It has only happened a couple of times, and each time it doesn't last that long. The first time was about three weeks ago. It was very cold out (around 0F), and it happened after the truck had started and warmed up a bit. I drove the truck earlier in the morning with no problems at all. After running fine for about 10 minutes, the truck started to sputter and lose power. I dove it like this for about a mile, then pulled into a parking lot. It was sputtering just a bit at idle, but it wasn't too bad while it was just sitting there. I desided to drive back home and put her in the garage to see what was going on (the truck lives outside - goes into the garage for work only). A friend of mine saw me in the parking lot, and I asked him to follow me home. On the way home (only 5 miles away), the truck seemed to clear up, and it started to run fine. I had my power back and it wasn't sputtering at all. My buddy said that it was smoking pretty bad with a blue smoke, but once he saw me accelerate away, the smoke cleared. I idled at home for a couple of minutes, then desided to fill up the tank (it was at 3/8 of a tank). Filled it up, and didn't have any problem at all until this morning. I was driving into work this morning, and about 20 minutes into my ride, I noticed a slight hesitation while going up a hill on the highway. I was going between 70 and 75 at the time. After the hill, it was fine. Then, about a minute later and the next hill, the truck started to lose power and started what seemed like miss-firing or missing on one or two cylinders. It started to get real bad, so I got off the next exit. I started taking the back-roads home, and it seemed to run fine. So I got back on the highway heading to work again. I figured I would fill up the tank again (at 3/8 of a tank again). I put like 15 gallons in to fill it. Got back on the highway, and the next hill it started to do it again. There is a dodge dealership about 5 miles down the highway, so desided to try to make it. Got to the dealership trying to figure out what I should do - leave it or just take a change with it. The truck was not sending out any codes at all. I desided to chance it (left it idling in the parking lot) and started back on the highway. Well, it made it to work no problem at all. I worked it pretty hard on the hills on the highway with no problem at all. From reading previous post, it sounds like it could be a lift pump, the VP44 pump (I would have guessed it would have sent a code), the MAP or AIT sensors, (but it's more of a constant throttle with a load on then an acceleration problem), or possibly a ground problem? Any other suggestions? I replaced my lift pump about 4k miles ago, but I don't have a gauge now to check that. Is it possible that there is some gelling or parafin collecting on the screen that is installed inside the fuel tank? I haven't heard anyone talk about that?? It's been very cold here the last couple of weeks and she sits outside. I do plug it in at night. The truck is in stock form. Any suggestions? Sorry for the length of the post.
- Mike
- Mike
