It's only fitting with halloween around the corner that my truck just started making weird noises. Atleast... I haven't heard them until now. There are two noises coming from the engine compartment area.
1. A high pitch humming sound that you hear only while accelerating to cruising speeds and while accelerating for a hill... nothing in tow.
2. A low pitch humming sound that you hear at highway speeds of 65mph or greater. It actually sounds like a truck with huge oversized tires on it passing you. It comes and goes but definitely is present more than it is absent. The sound can be amplified when you steer slightly left but will go away when you steer slightly right. FYI truck pulls to left as if misaligned but I just had an alignment with 4 new shoes the other day. Tire size 245/75/16 Is this a possible suspension part that is bad
Any ideas would be helpful. Thanks.
