2nd Gen Non-Engine/Transmission havac issue? help
2nd Gen Non-Engine/Transmission Drivers Seat
SSolderitch
I get no switching from floor defrost & panel. I do have vacuum and the recir door works & the panel/defrost actuator does move. The electric blend does change the temp. I cannot see the floor/defrost actuator without takeing things apart. I think I should buy a new switch in the dash first because it is easy to replace and if that doesn't fix it then replace the actuator? Which is more common to fail? switch or actuator?
