Have question for ATS Pulse Manifold users
Bully Dog 4" system
Intelltronix/Nordskog gauge problems
HEMI®Dart
The ends of my manifold won't go in very far to the center section. Maybe 1/2" then they stop. Airborne coated the male ends, but I just took some emery cloth and cleaned them up. They didn't want to go in before I had it coated.
Do I need to press them in or a hit them in with a rubber mallet? I have Anti-size on the male ends already. The ends of the manifold are in the freezer now.
No directions came with the Manifold.
Installing tomorrow.
Anyone have any tips?
[This message has been edited by HEMI®Dart (edited 04-27-2001). ]
Bill,
The Installation Instructions I have say to use a rubber hammer to pound the ends together. Be careful not to remove too much from the male ends. I found that the further in the male ends were, the easier they went. If you have a fax # I could fax you the directions (2 pages).
Dave
1996 Dodge 2500 4X4 SC, SLT,Cummins 12V, 5-spd. , JRE 4" exhaust (my kitty ran away into the woods and the muffler fell off!), TST 280 HP/685 Ft-Lb Uprate Kit, AFC Spring Kit, ATS 3-piece Exhaust Manifold, Chrome Valve Covers, Horton Fan Clutch, Jacobs/Ram Exhaust Brake, MagHytec Differential Cover, Prime-Loc, Rancho RS9000 Shocks, Combo Gauge, K&N Air Filter, Brite-Box, Geno's finger-touch oil pan drain plug, Optima Yellow Tops, no turbo silencer ring, full-time fog lights.
I use a brass hammer on the very end flange to press the outer parts into the center (put Never Seez or equiv. on the male and female joints). I use an old head for fitup as doing it on the engine would really be a pain. I imagine equalizing the bolt hole spacings per the directions would work fine, just take longer (that is, if you have a spare head available).
In a press fit situation the small thickness of the coating you had done could make a sizeable difference. Just a thought #ad
Clark
Say guys, as long as we have you cornered, are these ATS manifolds a step in the "bombing" process or the answer to a cracked stock manifold? (The "lust-for-list" is getting pretty long now, and selectivity is the new word!)
'96 2500 Black SLT 4x4 Standard Cab 5sp 3. 54, GearVendors OD, Wood dash, Sport headlights,Stull boards holding up 28" Hadley Diplomats, Pre-Luber, BFG 285 ATs on 5 spoke mags.
Thanks alot for the tips you guys. Without directions , I didn't know how to go about assembling the parts. I put the center section in the oven @ 300º and the ends in the freezer overnight. They still were tight. Used a rubber mallet to hit them in. I was sweating bullets for a while thinking what if I push to ends in too much. I'd never be able to pull them out a again. I didn't care for the 2 top bolts on the center section. Can't tighten them with an Allen socket. 3/8" or 1/4" drive, swivel or no swivel. I had to cut and gring an allen wrench to get to them. No idea how much torque they have. No leaks anywhere... ... yet. #ad
Double clutch, I am happy with mine so far. Boost comes on very quickly with less backpressure. I went from 5 psi to 45psi boost in about a second with 3/4 throttle.
Bill R
94 2500 SLT 4x4 5 Speed, 3. 54 LS, JRE 4" exhaust, Autometer Pyro, Boost & Water temp gauges, Bosch 215 HP injectors, Timing @ 14. 7º, JRE Stage III #4 plate 270/675, AFC spring kit, Scotty Air, Bully Dog Propane Injection, Roadmaster Active Suspension, Optima Red Tops, Geno's Exhaust Blanket, Espar Heater (won it!), Synthetic lubes throughout.
Coming Spring of '01: DD III's, Majestic prepped HX-40, ATS Pulse Exhaust Manifold, High flow delivery valves, Gov spring kit.
[This message has been edited by HEMI®Dart (edited 04-28-2001). ]
