Hi All,
This is kind of an emergency (last minute atttemmpt to get info before buying a tractor or not)... .
I am looking at what the owner says is a Ford 4010
industrial loader... . It as a 3 pt hitch and PTO and a platform for a backhoe attatchment...
The tractor leaks in 2 places... The power steering pump and underneath the tractor around mid way there is a hole with what looks like a bent cotter pin in it... . when you move the pin in the hole a bunch of fluid leaks out... . Fluid leaks are bad but what could be causing this? ... . I assume the fix would be to split the tractor and see what is leaking but is this a big concern?..... Interestingly I looked under my 8N and it too has a hole with a bent cotter pin in it... . but on mine no leaks... .
The tractor seems to work OK except for the 2 leaks... . I suppose power steering pumps are easy to come by or rebuild?... . It has a 4 cyl diesel and seems very powerful..... Owner is wanting $2350 for it..... I really like the unit but the leaks worry me... . esp the one through the cotter pin... . Also, the hyd fluid looks a little milky... . I guess this is from water??
Thanks for any and all help.
Andrew
PS My Email address is "Andyinchvill@earthlink.net"
Andrew
