HD radio
Racor Fuel Additive
Problems w/ Westach Fuel Pressure Sending Unit
I just put a new radio in my truck and went with a HD unit figuring if they switch radio to HD as they did TV I would be all set. I live in an area where reception has never been a problem analog signals came in good and strong. After installation I was not able to get HD stations. Later when I drove to work I was able to get em but on the drive home they went out again. Basically my HD reception stunk ( Getting about 30 -40 less miles coverage in HD) Spent a little time researching HD reception tonight and found that HD signals are being broadcast at a much lower power than analog (-20wdb ) whatever that means . One web site stated it was only 1% of the stations normal output. Just putting out a FYI for members who may be considering a switch to HD If you live more than 25-30 miles from a HD transmitter you may not be able to receive the HD signal.
Analog also has an advantage over digital in that analog signals degrade more gracefully. You may be able to hear a game from an analog station even with quite a bit of static but a digital receiver may not be able to process the signal because of all the noise. Same applies with HDTV over the air.
The Pioneer unit I got does both analog and digital. just kinda stinks paying extra money for something I can only use for 3 minutes of my commute. I'll see if I get my moneys worth on my next road trip
