well last week I had to pull my light duty(DLD) transfer case out to see why my overdrive wasn't working(broken sprag gear), so I decided to put in my(waiting in the wings) heavy duty transfer case(DHD)--for those of you who don't know the HD case is one inch longer and has a larger output shaft than the LD case and a pto --I procured a driveshaft(via willyslover) from his wrecked '98 3500 qc long bed 5 speed(my truck is an auto)--his driveshaft is larger in diameter and was one inch shorter(short is good because of the extra inch on the HD case), but the short part is in the rear part of the driveshaft which requires you to adapt your carrier bearing bracket by one inch to make it fit, as the front part of the rear shaft is the same length as my OEM shaft--also the one inch diff means you need to extend your front shaft one inch--I'm not sure if this will be a problem down the road only time and some research will tell---chris
