They can be reused (if they are not stretched beyond tolerance). Cummins sells a go/no go gauge to measure stretch (out of tolerance). Most Cummins service literature will give you the specs (lengths) for the 6 short bolts along the exhaust manifold. 12 med. lenght bolts along the head and the 6 long ones that retain the rocker tower to the cylinder head.
You should ck. the block with a straight edge and also the head to see if either require decking/machining.
A cherry picker (engine hoist) is a pre-req. unless you both are "he-men. " Then you won't damage the new head gasket on the re-install.
You are using the Marine gasket, which should be an update over your oe design.
Good luck
Andy
