Engine/Transmission (1994 - 1998) Head Gasket Install
Engine/Transmission (1994 - 1998) Towing Power Issues
I plan to install my new made in china head gasket today. Does the gasket go on dry or should I use some type of sealer?
The gasket and engine surfaces should be clean and dry. Spend a lot of time scraping the block and head with a single edge razor blade in a holder, and use lacquer thinner to get the surface clean. Mop out all the bolt holes with Q-tips so threading in head bolts won't force oil or antifreeze onto the block surface. The head bolts should be clean and oiled then left for the excess oil to drain off them.
Thanks for the advice, I followed Joes directions and got the engine running today. Will have to see how the MADE IN CHINA head gasket holds up.
Well everyone knows the Marines are the best of the best. After 3 months of head work at Paris Island it should be ready to go!:eek:
any quality auto parts store should be able to order you in a quality set made by fel pro. a cummins original would be from a chrsyler or cummins dealer
I got quoted 550. 00 to do the work including head gasket and replacing studs with ARP does that sound like a good price? I provide the gasket and ARP studs
