Well, time to fix the coolant leak in the right front corner of the head. At the same time KDP, hoses, radiator, gauges, etc. In the future looking towards #11 plate, gsk. . ? I do tow a 14K trailer loaded to 10K or so in the hills.
I am a flat rate auto tech but never touched a diesel engine before... any tips on a head gasket job? Mitchells on demand does not say replace head bolts. True? Is it worthwhile to change to studs?
Is it normal to NOT cut the head? If in specs and not cut what is the correct surface prep? (I have all gassers cut. )
Thanks.
Thanks.
