Engine/Transmission (1994 - 1998) Head Gasket Repair Procedure?
Engine/Transmission (1994 - 1998) Want 275 injectors.
Engine/Transmission (1998.5 - 2002) LED on with TC Lockup??
Hi All,
I am going to replace a head gasket in a 94 this weekend and was wondering if any of you might have a procedure or instructions that might make things go a little smoother. I have done a lot of head gaskets on 3406E, C-15, and C-16 Caterpillars, but I am new to the Cummins stuff. Any ideas such as addresses for online manuals or home-written stuff would be great.
Thanks in advance,
Ryan
CAT Diesel Tech
Please check the archives. Other members and I have posted a number of times with tips, part numbers, etc. Contact me off line if you can't find what you need.
Scrape the surfaces clean, wipe with lacquer thinner. Mop out every head bolt hole. It will take at least 100 q-tips.
Install gasket dry (Cummins 3283335 for stock thickness).
Oil head bolts threads and shoulders, let them drip onto a towel.
Torque in 4 stages to 115-120 ft lb. using Cummins sequence.
