How do you tell if you have blown a head gasket? I have a constant flow of white smoke coming out the stacks. The oil seems to be fine turbo also. Truck does seem to misfire. Is it fuel or is it a head gasket. I just added the TST PMCR a couple of days ago which brought my boost up to 45-48lbs, along with whatever it does to the cylinder pressures. I have thrown the following codes.
p0633 skim key not programmed in PCM
p0606 internal ECM processor
p0107 manifold absolute pressure sensor low
p0073 ambient temperature sensor high
Thanks for the help
Dan
Thanks for the help
Dan
