Head Gasket
07.5-12 Harmonic Damper question?
2014 Ram 2500 Crank No Start
TDEvans
Hi guys I got a 2012 Ram 3500 with a 6.7. Last trip out truck was running hot under a heavy load (trailer weights 18000) climbing some pretty steep grades, the fan is kicking when it is suppose to, at a shop right now and they think it's a head gasket. It's not using anti-freeze, and oil looks good, is there any other signs that it might be a head gasket, running on level ground with the trailer no problems, any suggestions are much appreciated, also quote to fix was over $5 grand. thanks Terry
If the truck is stock it is very unlikely it is the head gasket. If it isn't using coolant I would be more inclined to think plugged radiator, thermostat, or fan. Although you say fan is operating does it roar when coolant temp hits 218° -220°? And how hot is hot?
how hot is it running? 225F is the bottom end of hot... I've seen 225F climbing some mountains pulling my 5th wheel in the summer.. have seen steady 205F on the flats when ambients are around 100F... I just see if it starts cooling down by itself once the really tough climbing is out of the way, if it does it isn't something to really worry about. Now if it stays really Hot all the time it is another thing.
only other thing worth mentioning is if the coolant is old, it might be time to consider flushing the cooling system and sticking a new 190F thermostat in there.
Hi
Hi,sag2, yes truck is stock, 2012 with 153,000 miles, when fan cones on about 217, 218 degrees yes it is roaring you know the fan is on, and it is staying on untill it cools back down to 217 degrees, the highest it climbed to was 230. Ihad the coolant replaced at about 80,000,Right after that I lost a water pump,and they replaced the thermostat at that time. thanks Sag2
How many years ago was the pump and thermostat done? Were they Cummins parts? Did you lock out upper gears when towing the grades to keep rpm's up? I'm with @sag2, that a stock truck would need a head gasket at this time. Need to dig into it a bit further to find out.
Also, update your signature line with your truck info. It will help with any future questions that you might ask.
One simple thing to check is the external condition of the radiator on the inlet side especially. It could be partially plugged with bugs, dirt, etc. As noted above, a cheap aftermarket thermostat could be at fault also.
That's what mine had, badly.
I would agree. I have see 240* pulling grades with 18,000 in tow several times. Especialy when starting at the bottom and trying to come up to speed, and high ambient temps.
exactly.. my RV is at least 13k.. I've seen 225F climbing Wolf Creek Pass this summer. didn't think too much of it except the engine is working pretty hard..
those sort of loaded operation things are a different scenario than traditional overheating or running HOT.. where you have a hi cooling system temps on relatively normal driving.. I think people need to take conditions into account.. especially when cooling system temps return to normal when regular road conditions return.
This ain't your Grandad's 1st Gen where anything over 210* was too hot. Modern cooling systems are designed for higher temps as others have posted. I wouldn't freak out till I saw 225*+ and it didn't come back down.
I've seen temps as high as 242F on the work truck during the summer when it's a 100F pulling max weight up hills.
Hi, guys update on my head gasket issue,talked to the mechanic yesterday,from the loss of coolant, the pressure test he ran on the water system, and the test from the radiator with the water turning green,they said it was a head gasket ,it's in the begining stages. so to prevent worst damage I am having the head gasket replaced, thanks guys for all the suggestions
I hope you are not really going to spend $5k to replace a head gasket. That is outrageous money for a fairly simple job. I'm still voting for a plugged radiator at worst.
