Head light warning.
Head light warning.
Where to buy parts for a NP205?
Pardon my ignorance, but do our vehicles have a warning buzzer that will sound if the headlights are on and you open the door? Twice recently I've walked away and left the lights on, first time took a heavy duty boost to get started, second time my wife spotted the lights on. I work night shift, leave work for home in the dark, daylight by the time I reach home and I'm sometimes 99% asleep by the time I park.
The 1983 Volvo I drove for >11 years had this, saved me a couple of times.
If there is a 'buzzer' where is it located?
Thanks in advance.
Ian.
'93 D250 ext. cab. Upgraded injectors, 3. 5" exhaust, K & N filter, 4 gauge mount (tacho, boost, EGT, Xmsn oil temp), mirror tubes reversed, RACOR fuel filter, Xmsn oil cooler and fan, larger transmission oil pan filled with AMSOIL, 110vac inverter, alarm system.
[This message has been edited by Ian (edited 01-04-2001). ]
Ian, mine has the buzzer, buzzes for the key, parking lights and headlights. I pretty much have the same truck as yours.
1993 Dodge/Cummins D250 LE ext cab 185000 miles
1970 Dodge W300 Powerwagon with 8 ft dump bed
Ian, the warning buzzer is also connected to the seat belts, the same one is used for several functions. It may be possible that it was disconected. It should be under the dash to the left of the steering column. It's a rectangular box with an 8 pin connector, only uses 6 wires. There is information for troubleshooting the warning system in the service manual.
Neil #ad
Neil Copeman 92 D250,LE,limited slip, 16cm turbo housing, Isspro gauges, factory tach option, Lear cap, DC crankdown tire carrier
Hadley air horns, Stealhorse leather seats, e-mail (home): bombedcummins@sympatico. ca
Ian,
Good question, and I think you probably do have one, maybe just burned out or taken out by somebody else. I hated mine with a passion because it sounded for EVERYTHING #ad
. I found mine by sonar (turned lights on and open the door, then listend with my hands up under the dash to the right of my steering column), and promptly removed the offending piece of plastic. Gladly give you mine if you find yours is missing or broken. Email me your address and it'll be in the mail if you need it.
Good luck,
Ken
'93 W350 CC 4x4 5spd, Banks Stinger (turbo-tailpipe) kit.
Ian, my 92 has that buzzer. I disconnected the plug for the seatbelt - found it was a real pain, when I am hunting and driving in the bush I never put my seatbelt on.
Al
92-LE,4x4,5spd,3. 54,Borgeson steering shaft, Tach,Isspro Pyro & Boost, 16cm2, PW injectors
Ian, I've done the same thing more times than I want to admit. I looked once but didn't find the buzzer. At least I know where to look now! #ad
Stan
93 2WD extended cab, Banks Power Pack, K&N Air Filter, PW Injectors,Auto w/4. 10 rear with limited slip, US Gear Exhaust Brake, 31/2" Exhaust, 5K air bags, Boost/Pyro/Tach Gauges, Green/Silver, new 40-20-40 bucket seats, 149K
[This message has been edited by paccool (edited 01-05-2001). ]
