Details here: TDR Privileges
I lost my head lights the other night . I have high beams if I hold the high beam indicator back otherwise no lights. oh where should I start all fuses are good.
Curt,
It sounds like you have melted the head light switch. Pull the trim off the dash and remove the head light switch and look at the plug in the back. I think you will find it melted. Go to Kragen and tell them you need a switch and the wiring harness / connector that it goes to. You will then have to splice the new connector into your harness. Make sure you sodder the connection and and use the supplied heat shrink tube. I have done mine twice. The cause is too much power going throught the head light switch to the lights. Harlan
