My head gasket finally let go just behind the thermostat housing. The quotes I'm getting just to get parts for repair are more than double what I paid for the whole motor so I need some advice.
I'm told 9 out of 10 heads are cracked and that I should just start over with a brand new complete head from Cummins. Another reason I've been given is that with an engine having over 100,000 miles, valve seats, seals, etc. will need replacing. Supposedly prices add up to near the price of a new head, which I'm told is $1,200, plus $350 for o-rings and a head gasket. Calculating costs to ship my head, have it disassembled and magnafluxed, then decked, o-ringed and rebuilt replacing parts most likely worn, will cost around $800, with shipping being nearly half that amount. I don't want to spend a few hundred just to have the head checked out and find that it needs replacing.
Is it true that the head is usually cracked if the gasket is leaking? I definitely expect warping since the engine has overheated many times and EGTs are very hot. What about the head needing to be rebuilt? I've got heavy duty intake and exhaust valve springs so I'll probably have to eat that cost when swapping mine onto the new head.
I was hoping Cometic would have a gasket solution that wouldn't require o-rings, but they told me today over the phone that they've had so many leakage issues that I'd have to sign a waiver to get one. Sounds like a risk I don't need to be taking. They've been working on a redesign for months and have no idea when the revised gaskets will be ready.
So I'm looking at a stock thickness replacement Cummins head gasket. I don't want to lose any compression as cold weather starting is already hard enough. I also don't want to sacrifice any low end response since my truck is a rock crawler.
One of the biggest decisions I'm now trying to make is which ARP head studs to get. I already make over 47 psi boost with my single HTT 62/12 and water injection and 17. 5 degrees of timing in very cold weather at 7,000' elevation. I plan on compounds and nitrous someday and from what I've read and been told, the regular 12 MM head studs may not have enough clamping force for my future plans. The 625 12 MM stainless steel ARP head studs are supposed to hold as well as 14 MM studs. Do I really need to spend more than double for the 625 studs? Are they worth the extra money?
I'm also wanting to have the head ported. I've seen huge results from folks porting heads on motorcycles, and know a guy who did it on his own Cummins and gained 2-3 mpg, much lower EGTs, and greatly improved drivability power. I'm curious how great the results are for other Cummins owners from porting the head.
I live a couple hours from Salt Lake City. Gillette Diesel is recommending a shop over a hundred miles further south for any and all Cummins head work, haven't talked to the guy myself. I work an average of 15 hours 7 days a week and have no shop so I will have to be paying for not just the parts, but all of the labor as well.
Does anyone have recommendations for best prices, quality and service on regular or 625 head studs, a complete, brand new Cummins head, stock thickness head gasket, and head porting? Any constructive advise regarding which parts I need and what I should be paying for the work is welcome.
