1997 1 ton, stock form. Cylinder head was replaced for a cracked one and turned this truck into a pooch, same truck with a 3. 9 would smoke it up! Different casting number but local Cummins dealer oks it. Pump and injectors removed and bench tested, anroid functioning properly, boost pressure good, connector hose on CAC was replaced and was assumed the problem was cured. Fuel pressure runs ok, turbo free, exhaust open, timing good, proper head gasket, gets a little smoke but still a poke. Is there a problem with injector protrusion? Im not sure but I think they ran the gambit with different thickness seals. Casting differences? Any help would or ideas would be appreciated. Feel free to second guess any of the above!
