Engine/Transmission (1994 - 1998) Head Work
Engine/Transmission (1994 - 1998) 5th gear fix
Engine/Transmission (1998.5 - 2002) T-Stat and lower rad hose questions
Is having a head o-ringed and fire ringed the same thing? What should it cost to have it done and who in the Houston area would you recommend? Thanks
Shoot Mike Watkins (MDW on here) a PM. . he is the owner of Hot Rod Diesels... He would be more than glad to help you out!
-Chris-
Oringing and fire ringing are not the same.
Oringing uses the stock gasket and squeezes the wire oring into the firering in the stock gasket.
A firering replaces the firering in the stock gasket which requires a gasket with the ring removed.
The firering setup is showing to be a better system but does require more work.
I would be glad to visit with you, give me a call.
Michael @ HotRodDiesels.com
Also Chris at Relentless is very good at what we do, don't hesitate to call him.
