headgasket ?s and others
im despret for help finding a part for 1st gen truck
Braided brake lines
Where can i buy a good beefed up headgasket for my truck from? and a stud kit??? Is anyone on here from the jersey area or anywhere close by???? And is there any national type first gen shows or meetings or anything like that ever?? JUst some stupid questions thanks??
You can get head gasket kits from your local Cummins shop. When you pull the head, have it milled flat, and then you can get . 010,. 020,. 030, thicker head gaskets in accordance with how much the machine shop takes off to make it flat.
I've not shopped for head studs in a while, but most any performance shops can get them for you. Pete Toombs here should be able to hook you up with a local shop to you.
Michael
Micheal's truck isn't to high. I am 6' and I only needed a 3 foot step ladder to get in. :-laf:-laf
Just kidding.
Just kidding.
Hey, you've never even seen that truck in person!:-laf I'm bringing it to SOP the next time and making Scott put a governor spring in it!!! Seriously though, when I purchased the 90, it already had the lift springs in it, and the previous owner forgot what they were. I believe it has a 6" spring lift, and lots of fender trimming. The front opening of the fender goes right through the turn signal hole, and the rear cut about even with the front of the cab. It was rusty and dented retired farm truck when I got it, and I put lockers and swampers on it, and its my trail pig. Still working on a 47re/rh to switch out the 727.
Michael
