Ok, have had a chronic problem every now and then in my '02. Going down the highway at night, once in awhile if you hit the dimmer switch to dim the hi-beams, it will shut the headlights off competely. Only way to get them to come back on is to hit the dimmer switch and bring the hi-beams back on. Usually then you can dim them to low-beams and everything will work. Tonight something else happened, I got off work started my rig and after a brief warmup I went to turn the lights on with the dash switch. Nothing. Gave it a second and they finally came on. Im thinking one of the two switches is bad. Any insight?
