Headlight adjustments
Proper Shifting of a Hand Shaker
Looking to buy, I need help!!
I have a question about adjusting headlights. I know there are a couple of screws to adjust the headlights up/down and side to side but how do you know when/how to make the adjustments? I seem to remember that you parked the truck so many feet away from a blank wall. Turn on the headlights and see where they are pointed. I thought that at 6feet away the headlights should be about knee high on the wall. Is this correct in any way?
Thanks
Dawna
Dawna
Level Ground, 25' away from wall.
Bounce front end a few times than measure height of headlights off ground and distance between two light centers. .
Purpose is to mark wall with straight ahead center beam for each light.
Aim center of each beam straight ahead and 1/2" to 1" below level.
