I am having a problem with the headlights, taillights, parking lamps and my gauges in my truck. About 2 months ago I was driving my truck, I traveled over a rough spot on the road, then the truck shuts off. Fuel pump is still running, no check engine lights or anything. Truck started back up like nothing happened. Drove fine for about 3 weeks. I put 1000+ miles on her since then and its been fine. Then about 1 month ago I drive the truck to work, again, truck is running fine. In the evening when I got to drive home, I have no low beams, 4 ways or turn signals. After some forum reading I found out that either the PDC or the FCM or both go bad. I figured I would try an FCM seeing as how it was just my lights that were acting up and it was the cheap(er) route. I got my new FCM in and it actually made the truck worse. Almost none of the lights worked, and my gauges would intermittently drop out. ABS, Brake, Air bag light would come on at random times. So I decided to order a PDC. Once that arrives, I installed that and it did really no difference. I had 2 codes one was for my fuel pump, which I actually pull the relay out anyway cause of my aftermarket air dog, and the other was a P1652 which is a short on the Comm Bus. I cleared both codes. Truck runs and drives fine, Still have my light problem and the gauges still dropping out at random times with the Warning Chime, Brake, ABS, Airbag light randomly coming on.
After I cleared the code the truck still exhibits this behavior, however no codes are showing up. My Auto technician friend ran the diags for that code (Test for continuity along the D25 circuit) The result was 800 ohms. 10 or less is a short. over 10 is a faulty ecm.
I also noticed too that my horn, wipers, overhead temp gauge intermittently do not work. All of these are controlled my the FCM.
So my question is, did I just get a faulty FCM and it his screwing up the gauges in my truck, or is the ECM to blame for messing up the FCM ?
Any help would be appreciated!
Thank you!
Thank you!
