Details here: TDR Privileges
I'm trying to replace my headlight bulbs. I removed the 3 torx head screws and the little plastic screw that holds the rubber trim piece on but after that I'm stuck. I didn't think I was that slow! Any help would be appreciated.
You are about there. Just grab the outside corner with your fingers and grab the inside with your other hand and pull stright out. There is a little plastic barb that hold the light in place behind the headlight assembly. Go to this website and click on the install instruction link and scroll down a little and it will tell you in detail how to remove the light.
