Hi Everyone: Having an issue with my headlights. Backstory:
I replaced my factory switch due to it melting on me a couple years ago. The plug and pigtail of wires was badly distorted but I have affixed it to a new switch. It has been installed for a couple of years.
Recently while on a trip, I stopped for fuel and shut off the lights. Upon continuation, the low beams would not come back on (holding the column dimmer switch depressed for hi beams allowed me to find a place to pull over) so the high beams and low beams do not work when the headlight switch is on (just the park lights -- again you can hold the dimmer back to get hi beams but they do not stay on). I let the switch cool down for a bit and was able to get the lights working again (no smell of overheating either mind you)
The other morning in temps about 10 degress out, the headlights did not work after warming the truck up. I couldn't get them to work. I will pull the bezel today and check the connections.
They seem to come and go with little rhyme or reason. Does anyone have a suggestion? The truck is worthless to me when the lights can't be counted upon to work flawlessly.
I should mention the truck is a 98.5 24v. I replaced the headlight switch with an Echlin from Napa.
