2nd Gen Non-Engine/Transmission Headlight problem.
Engine/Transmission (1994 - 1998) Oil Ratings
Noticed today as I pulled into the driveway at dusk that my headlights weren't on (switch was though) :{ . Flipped the column switch and the hi beam came on. Flipped it again and the lights went out. No low beam :(. Pushed the headlight switch on and off without effect. Remembered I had removed the dash and lowered the steering wheel (using the adjustment lever). Repositioned the steering wheel up and the low beam came on. Repositioned the steering wheen down and the low beam went out. Does anyone know how the wires route from the low/hi selector on the column to the dash(are they inside the column shaft or outside)?
I really don't want to disassemble the column but don't want to take a chance the wires are broke and could short something out (or set off the air bag) :( .
