Headlight problem??
Source for DPDT switch? (for dual pyros)
Ordered 04.5
My left Headlight sometimes does not come on with the turn of the headlight switch. Also sometime driving down the road the light goes out all by it self and the Lamp Out indicator comes on ...
Now when the light goes out while driving, it usually only flashes out long enough to make the lamp out light come on an ding!!!
What does anybody think!! There are no codes!!!!
Thanks
Ken
Check your grounds on the drivers side above the battery area, Tight and clean. Or you could have a defective bulb.
Checked grounds, replaced bulb!!
Seems to not come on after a 15min + idle warm up!!!
And occasionally goes out while driving...
I am thinking the BCM Front now the trick is getting the dealer to fix the problem!!!!
ken:confused: :confused: :confused:
