switch and relay
The package I have from Dodge has the following numbers:
1- CAJM8190
234890A
The date on the plastic envelope is 07/21/03
There is a bar code and the letters CAJM8190 are repeated beneath that.
This is a switch kit with relay that Dodge sells for these trucks. I think it is the same as the later model trucks. There is a new switch, a set of replacement wire ends, the plastic block that the wires terminate in, some shrink sleeves and the relay. Somewhere I have a set of instructions to install all this but there are no instructions in the package. Can't say if they willl help as I have not installed the kit. In the life of the truck, the switch has been changed about four times due to D350 lighting and pulling a trailer most of the time. I pulled a seperate (fused) wire to run the trailer lights and have not had trouble since.
James
