Headlight switch lighting
OK, done this, so what's next?
Engine Warrantee
Has anyone had trouble with the light on their headlight switch not coming on when the switch is turned on? Mine's been doing this for about a month now, and I can usually get it to come on with a quick tap to the top of the dash, so I'm thinking it's probably a loose connection somewhere in the switch.
Can someone with a service manual point me to which wire on the back powers the light? Or does it have a bulb that can be checked?
I wanted to get a few suggestions before I pulled the switch out.
TIA,
Justin
Mine does the same thing if I "flash" truckers with the dimmer switch to let them know they are clear to re-enter my lane. When I turn on the headlights I have to go to bright, then back to dim to get the headlights to come on. I'm sure it is a dimmer switch problem, but it hasn't failed completely yet, so will live with it.
Well, I pulled the switch out tonight to take a look at it. All the connectors on the back looked to be in good shape and making connections. I didn't see any way to get into the switch to check the bulb, so I guess this goes as one whole piece.
Anyone have any ideas what a new switch runs? I'll check around tomorrow, and if it ends up being too much I guess I'll put up with a non lighted switch.
Justin
